Re: "floating " light coil for led source
el pollo /
you are screwed up with names, you changed ground. that makes an ac stator dc. it also gives twice the output. a excellent repair but its not floating. honestly you can't float ac period. end of story. ac floats by definition.
so what floats, dc only. the dc output could be considered floating. why because its not steady. when the dc voltage gets to 14.3 the regulator turns on. below 14.3 the regulator is off. the voltage floats with the regulator. 14.3 is the average voltage from the regulator. some times a bit higher other times a bit lower but when its on the average is 14.3v. that's the float. I don't care how many times you check, the frame is 0 with a dc stator. full wave dc ground does not float. on an ac stator you can run 1/2 wave. you float ground with an ac stator. ground is still zero but you can't use it because the ground coming out of the regulator is -7.16. when you float ground you use only the + side of the wave. what this means is ground can't touch the frame. ground floats isolated from the frame.
  "floating " light coil for led sourceTopic by: Marc Friedman Marc Friedman 09/22/19 01:23PM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/22/19 03:23PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/22/19 07:11PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/22/19 04:30PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 08:06AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 08:21AM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/23/19 10:51AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 08:56AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/23/19 09:09AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 09:38AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/23/19 11:01AM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/24/19 07:40AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/24/19 08:34AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/24/19 09:19AM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/23/19 08:06PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 08:37PM
  Re: "floating " light coil for led sourceRe: Dave Steele Dave Steele 09/23/19 11:07AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 11:33AM
  Re: "floating " light coil for led sourceRe: Dave Steele Dave Steele 09/23/19 04:15PM
  Re: "floating " light coil for led sourceRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/19 05:00PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 05:14PM
  Re: "floating " light coil for led sourceRe: Probably Fred Probably Fred 09/23/19 05:33PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 05:50PM
  Re: "floating " light coil for led sourceRe: Steve Paul Steve Paul 09/24/19 10:14AM
  Re: "floating " light coil for led sourceRe: Graham Motzing Graham Motzing 09/24/19 01:10PM
  Re: "floating " light coil for led sourceRe: P D P D 09/24/19 01:59PM
  Re: "floating " light coil for led sourceRe: Graham Motzing Graham Motzing 09/24/19 02:30PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/24/19 02:04PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 03:02PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/27/19 03:28PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/27/19 04:14PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/28/19 08:20AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 06:36PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/27/19 10:14PM
  Re: "floating " light coil for led sourceRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/29/19 01:15AM
  Re: "floating " light coil for led sourceRe: scrot rash scrot rash 09/29/19 09:20AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 09:24AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 10:14PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 10:16PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/28/19 12:31AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 10:40AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 11:08AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 12:32PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 12:48PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 12:59PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 01:08PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 01:30PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 02:20PM
  Re: "floating " light coil for led sourceRe: P D P D 09/28/19 04:31PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/28/19 05:39PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 06:44PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/29/19 08:30AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 09:42AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 10:00AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 11:41PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 01:49AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 06:44AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/29/19 09:28AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 03:00PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 09:43AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 10:06AM
  Re: "floating " light coil for led sourceRe: Jesse Simonsen Jesse Simonsen 09/29/19 04:13PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 05:38PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/29/19 08:24PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 07:47AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 10:46AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/30/19 11:21AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 02:42PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/30/19 03:37PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 04:24PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/30/19 05:17PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/01/19 08:44AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/02/19 10:21AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/02/19 10:42AM
  Re: "floating " light coil for led sourceRe: Jesse Simonsen Jesse Simonsen 09/29/19 08:36PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 11:22PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/29/19 06:42PM
