"floating " light coil for led source
Marc Friedman /
This is such a repeat over and over question about 12v rectified / regulated lighting so leds can move reliably used that I decided to post this picture seeing I'm doing thisntona hpi mini.
As I've previously said hpi listened to various desired for floated ac so they made it easier to do it. Not as easy as they should on this version by not as hard as older generations. This one the cdi ground ( black wire and the back side of the three lighting coils end together so separate then with a side cutter and then silver solder the wire to a new second wire and bring out under the stator and include inntheboutbound wiring harness. Yes!!! I was somewhat delirious the day I put t on the mutant hobbit ad forgot this cdi wasn't floated hence now I'll end up probably needing to pull stator etc to get it all out and secure. I'll put a bit of shrink wrap over the soldered connection
  "floating " light coil for led sourceTopic by: Marc Friedman Marc Friedman 09/22/19 01:23PM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/22/19 03:23PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/22/19 07:11PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/22/19 04:30PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 08:06AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 08:21AM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/23/19 10:51AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 08:56AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/23/19 09:09AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/23/19 09:38AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/23/19 11:01AM
  Re: "floating " light coil for led sourceRe: ♣Slew Foot♣ ♣Slew Foot♣ 09/24/19 07:40AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/24/19 08:34AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/24/19 09:19AM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/23/19 08:06PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 08:37PM
  Re: "floating " light coil for led sourceRe: Dave Steele Dave Steele 09/23/19 11:07AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 11:33AM
  Re: "floating " light coil for led sourceRe: Dave Steele Dave Steele 09/23/19 04:15PM
  Re: "floating " light coil for led sourceRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/19 05:00PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 05:14PM
  Re: "floating " light coil for led sourceRe: Probably Fred Probably Fred 09/23/19 05:33PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/23/19 05:50PM
  Re: "floating " light coil for led sourceRe: Steve Paul Steve Paul 09/24/19 10:14AM
  Re: "floating " light coil for led sourceRe: Graham Motzing Graham Motzing 09/24/19 01:10PM
  Re: "floating " light coil for led sourceRe: P D P D 09/24/19 01:59PM
  Re: "floating " light coil for led sourceRe: Graham Motzing Graham Motzing 09/24/19 02:30PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/24/19 02:04PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 03:02PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/27/19 03:28PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/27/19 04:14PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/28/19 08:20AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 06:36PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/27/19 10:14PM
  Re: "floating " light coil for led sourceRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/29/19 01:15AM
  Re: "floating " light coil for led sourceRe: scrot rash scrot rash 09/29/19 09:20AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 09:24AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 10:14PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/27/19 10:16PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/28/19 12:31AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 10:40AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 11:08AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 12:32PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 12:48PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 12:59PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 01:08PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 01:30PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 02:20PM
  Re: "floating " light coil for led sourceRe: P D P D 09/28/19 04:31PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/28/19 05:39PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/28/19 06:44PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/29/19 08:30AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 09:42AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 10:00AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/28/19 11:41PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 01:49AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 06:44AM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/29/19 09:28AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 03:00PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 09:43AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 10:06AM
  Re: "floating " light coil for led sourceRe: Jesse Simonsen Jesse Simonsen 09/29/19 04:13PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/29/19 05:38PM
  Re: "floating " light coil for led sourceRe: ken gilbert ken gilbert 09/29/19 08:24PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 07:47AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 10:46AM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/30/19 11:21AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 02:42PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/30/19 03:37PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 09/30/19 04:24PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/30/19 05:17PM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/01/19 08:44AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/02/19 10:21AM
  Re: "floating " light coil for led sourceRe: el pollo el pollo 10/02/19 10:42AM
  Re: "floating " light coil for led sourceRe: Jesse Simonsen Jesse Simonsen 09/29/19 08:36PM
  Re: "floating " light coil for led sourceRe: Marc Friedman Marc Friedman 09/29/19 11:22PM
  Re: "floating " light coil for led sourceRe: Dirty30 Dillon Dirty30 Dillon 09/29/19 06:42PM
