1979 Honda Express
My 1978 Honda Express will only crank if I remove the entire air breather box and will shut off if I try to run it attached. It cranks right up and runs if I have no air filter box on it. I have changed the foam with the correct Honda part. What are my options? Thanks in advance
Re: 1979 Honda Express
Runs fine otherwise? Try a thin filter, like another guy is running a layer of pantyhose. You need something there. You sure the choke or enrichener isn't partially on? (edited)
Bonnie Blake /
will try that Thanks!
There are some great experts on here for Honda Express...………..I hope they will chime in.
Clean the carb, Take all the way down to clean.
Consider exhaust clogged as a possibility.
Bonnie Blake /
Thanks for all the suggestions. Will definitely follow them
open the air screw to see if that helps
