?one way bearing for Vespa
so as luck would have it I mounted this new baby on my bravo and neglected to grease the bearings and ate the bearings. But now I pressed them out with an arbor press and now all I need is one or two one way bearings and it will be a pedal start moped ready for say a mlm water-cooled head.
Is there a flaw in this plan?
Re: ?one way bearing for Vespa
Did the transmission shaft get messed up when the bearings gave out? Are you running 2 one way bearings in the clutch?
Marc Friedman /
The pictures I posted were of the clutch housing with the stock bearings pressed out. So no bearing at all are in there. I plan on taking that and a functioning rear tranny to a bearing shop and seeing if they can find a one way bearing with the same od and id as the original needle bearings. And if they exist I'm wondering if I should put a single one way and two one way.
So I'm posting it to see if anyone else has tried this or is planning on trying this etc etc. I suspect a one way this size may not exist.
Marc Friedman /
And nothing happened to the shaft. The bike wouldn't idle unless it was on the stand. It would stall at a stop sign as it should if those bearings won't turn.
I wasn’t having any luck finding a one way bearing that will work with a 13mm shaft. Treats says the bearings in the clutch are HK1312b which is 13mmx19mmx12mm
I found this one but it’s a standard size
1/2x3/4x1/2 the metric converts to .512x.748x.472. Will .012” smaller dimension on the shaft work?
https://www.vxb.com/RC081208-One-Way-Needle-1-2-x3-4-x1-2-inch-p/kit8651.htm
Marc Friedman /
Yea so far that's what I also found on the internet. So I agree , my hopes are high and expectations low. I've now been taking apart and reassembling all my collection of rear clutch pullys etc so I finally understand some of the issues.
Dirty30 Dillon /
I feel like there are enough other options for Vespa where this should be an issue.
You can buy multiple brands of pull-starts, and even factory kick starts. If someone produced a decent derbi pull start I would ditch the one-way in a heartbeat
find a new one, press it in, if everything else is ok, shud be fine. carful not to squish the bearing case thing. is there more to this? i might just buy a new cutch. they're cheap now.
