Re: Bing carb slides?
Probably Fred /
Mostly just #41 and #24 for 12-15mm bings and numbers is for cutaway and you can sand your own cutaway making larger 41slide has a air hole which you can add to any slide
You you really don’t wanna have a slide open much past full carb bore because that creates turbulence,
So it’s hard to set it up with your cable because making a corner you may not necessarily have slide correct open but a lot of times you have to back off a bit so the slide is even with the top of carb bore not much recessed into the top,
What do you need to do is turn the Bendy in/adjust the bendy some in some so your carb slide hits it and it is pretty much even the top of carb bore not much past @ full throttle, to adjust bendy cable guide you have to remove the choke lever
