1978 Honda Express Fuel Mixture
Can I run my Express on a premix like Truefuel 40:1 without disconnecting the oil pump. Like use it in the gas tank without adding any oil to the oil tank? I am sorry if this a dumb question but just trust your input.
Re: 1978 Honda Express Fuel Mixture
You can, but I would disconnect the oil pump if you do, is the pump not working?
You can use a “T” fitting to connect both tanks.
Bonnie Blake /
I actually do not know. I just purchased it and don’t know if has been disconnected or not or is working . I would just like to use the premix if possible. Thanks for info
Bonnie Blake /
Any good place to find out how to do this?
It’s better to eliminate the oil tank side because the gas side is so small so you’ll be able to run more gas. Run 50:1.
If it’s hooked up through the intake unplug the line and plug up the intake nipple. If it’s through the carb do the same thing. You can leave the pump in just block it up.
