Good premix ratio for cbd?
Im going to try it untill it seizes this chinese minarelli horizontal . Im going with 32:1 wot rippin dick pulls all the way to the end of the block by my shop.with video. Guess at what premix ratio it seizes for a (huge)free box of stock revival parts.
Re: Good premix ratio for cbd?
Umm, 420:1
♣Slew Foot♣ /
120 to 1 but if you add Dura Lube and Marvel Mystery Oil 300 at 4 to 1 guesstimate
Probably will seize at 32 to one
Bad Cadillac™ /
With no dick pull videos, this post is worthless...
20mg's is a good starting point.
♣Slew Foot♣ /
I mean you want to trash an engine I got a Saks Bing 54 that you can run 4 times the amount of fuel which put your right in the range and nitromethane and graphite you need a cast-iron cylinder though and it probably wouldn't hurt to have it water cooled you want to make a destruction video I will donate to the cause... the carb came from a 250 two cycle rear engine from a ultralight it even has a nitrous oxide in Port into the float Bowl for altitude
What about hemp oil?
> live ɘvil Wrote:
> Umm, 420:1
♣Slew Foot♣ /
Yeah try to find out a ratio for hempoline
Maitland Of the Loin /
I used to run marvel mystery oil instead of 2 stroke on stock bikes, it never siezed
I'm following this one, just out of curiosity.
Isn't it gonna smell like reefer as your brappp around? :D
I got a sponsorship out of California. I didnt know a ounce of this stuff cost so much. This project now brought to you by #smokefaces. Anyhoo, i have a scooter with iron ebay kit on it that will be a perfect test mule!
♣Slew Foot♣ /
I'm wondering because you could run hemp o Leen in a diesel supposedly as long as it's hot it will run on just hemp o Leen until you stop it and it cools down and it won't compress and ignite some old guy in South Africa told me that about my sax that if you ran out of gas you could use diesel to get home as long as you didn't stop it cuz then you'll have to clean out your carburetor and jets and everything
Want to reply to this thread?
