Blendzall octane booster+2t oil question
Hi guys, So has anyone used this oil? How does it compare to, say Motul 800 or Klotz super techniplate? My motor build should spin around 16k rpm so I need protection.
Re: Blendzall octane booster+2t oil question
Dirty30 Dillon /
Wear a Condom
Zeeshan Hb /
> Dirty30 Dillon Wrote:
> Wear a Condom
Lmfaoo
Probably Fred /
Race bike ?
Definitely not a Normal Street Moped
Zeeshan Hb /
Pretty much.
Probably Fred /
> Zeeshan Hb Wrote:
> Pretty much.
Well post your set up !
Zeeshan Hb /
Not sure technically it's not a moped but a scooter based Engine. 7075 custom aluminum crankcase, Athena 70cc hpr kit, malossi rhq 39.7crank, polini c4 bearings, skf nitrile seals, Custom ignition system (edited)
Zeeshan Hb /
But can we get back on topic?
I have tried 460 Green with two shots of 490 before and it is good Castor and no detonation. That combination did not seem as dirty as Castrol or Klotz, other than that it was same same for keeping EGR temperatures down even for extended periods on the pipe.
According to Blendzall it seems 485 is just 490 with 5oz of 460 in it...
Zeeshan Hb /
Ok so it's good ?
Yes indeed 460 Green with 490 is good... so the all in one formula should be good...
> Zeeshan Hb Wrote:
> Ok so it's good ?
Zeeshan Hb /
Alright I think I wanna try it.
