I'm (trying) to build an 81'50v with a LePartie cdi. I have the ignition "part" nailed, the bike starts easily idles smooth, revs/runs excellent.
However, I'm having a HELL of a time getting all the accessories (lights/horn/brake lights) to work simultaneously. I have a brown wire that sends power to the horn and brake lights, and a white that sends power to the headlight/tail light, and speedo lights. All wires, switches, and ground have been meter tested for function. shorting, and continuity.
If I put the output wire from the regulator to the white (that sends power to the head/tail/speedo lights), all those function perfectly with the light switch on top of the headlight, but I have no power output for the brown (brake lights/horn).
If I send from the regulator to the brown, the horn and brake lights all function perfectly with their proper switches, but again it leaves me with no power source for the head/tail/speedo lights.
I made a y-connector to try to send power from the one source (regulator) to both wires, the headlight/tail light/speedo light all stop working BUT flash with the horn button or either of the brake light switches ....
WHAT'S WRONG??!!???!??!
How do I get both systems wired from the one power source without the brake light/horn switches turning on (flashing as used) the head/tail/speedo lights?
