Re: Exact size of dellorto bushings
Rebel Moby /
Shim is only there so the clamp on the carb can actually grip the intake, for a goodly seal you need to use a oring at the carb to intake union.
5/8 x 13/16 x 3/32 oring is a great fit into the 14mm carb sizes, 11/16 X 13/16 X 1/16 oring will suit the 15mm SHA.
