102 SP tail lights not working
Peugeot 102 sp tail light not working. Any ideas. I know the light works bcuz I tried it on another ped. Headlight and horn both work. No running lights or brake lights.
Have checked all grounds. Any ideas?
Re: 102 SP tail lights not working
Corrosion in the socket? Wire pinched/cut under the fender?
your running lights and brake lights dont work ?
make sure on the wiring harness, bulb sockets, and handlebar switch assemblies that you have nice tight connections on the bullet / spade connectors and that they are not corroded or oxidized
Would be a good idea to take a multimeter (like $20) and test the connections to make sure they are getting power if visual inspection fails to yield results (edited)
