Re: Flywheel magnet strength
Rebel Moby /
Corners of the magnet?
I am thinking it would make sense to have them aligned with the magnet with the poles agreeing, perhaps epoxy glued to the flywheel...
I will have to gather some iron powder and check if this will work to increase the flux or no...
> P D Wrote:
> To clarify , any weak magnet should be able to be made stronger when
> parred temporarily to/with a stronger magnet in the correct manner . How
> long and at what level the effect will last would be limited by the
> 'quality' of the base material of the weak magnet .
> I am debating which method to use , one or maybe both :
> Attaching small neodymium ( N52 ) magnets to the corners ( North & South
> Or , rubbing / stroking the weaker magnets with a single bigger / much
> stronger neodymium magnet .
> The flywheel I'd experiment with will accommodate small magnets on the
> back outside corners of the installed permanent magnets . Obviously ,
> the small magnets would have to have the proper north/south orientation
> to be any kind of effective .
