Re: Flywheel magnet strength
P D /
> Rebel Moby Wrote:
> Just wondering how you determined the magnets were weak and not the
> coils having internal shorts from insulation breakdown in the magnet
> wire.
Bulb , plug and wire / connection testing was my first step .
That all was copacetic .
Coil testing was my next 'step' .
I tried a couple different coils , on of which was new . All 3 coils produced pretty much the same . I rewound one of the lighting coils with what I consider excellent results , but still on the marginal side .
That left the magnets .
Using a bolt and my feel for pull , the simplest method , I compared magnets from different flywheels .
It was pretty obvious that the magnets in question were noticeably weaker .
I tried the stacking method of strengthening a weak magnet . I only have a round ferrite magnet that has a strong pull . I believe the weak magnets are stronger after the 'partnership' .
It seems to me that the weak magnets can be made much stronger , enabling a better/closer to optimal output from the system .
