How to: convert your Tomos 5 stars to sealed bearings
Dan (high idle) Conway /
So, I said i’d do this in another thread so here goes.
I started by fumbling my back wheel off the bike after finding a concerning amount of play in it after a long ride.
After putting it up on the table and removing the axle, I used a rubber mallet and a huge screwdriver to push out the bearing races. Make sure not to scratch up or fracture the mating surface in the
process,
Re: How to: convert your Tomos 5 stars to sealed bearings
After giving the races a good clean, I took out some red threadlocker by Loctite and gave one of the sides a good dose, spreading across the mating surface of the bearing.
Next I grabbed my bearing, my puch maxi seat post, and I dropped the bearing in place.
Once the bearing was seated, I
took measurements around the outer race and the hub to make sure the spacing was equal all the way around.
Now... DONT FORGET THE SPACER!!!
I say that as it is probably a huge pain to have to pull out a perfectly seated bearing with red loctite, and you can only use this spacer when one bearing is removed.
I measured the depth of the hub from edge of the bearing to edge of exposed bearing/hub mating surface.
I found my spacer was too big, soo I cut it, sanded it and checked the fit.
I then repeated the last step, this time with the spacer and new 12mm axle in place.
Ps here’s a shot checking the final bearing seating.
I then spaced the brake plate out away from the bearing, using the old spacers from the loose bearing axle, and dry fitted it on the bike.
I found I needed some more spacing between the hub and swingarm, so I cut down the scrap piece from the spacer I used earlier, fitted it on the sprocket side, and measured the brake side, this picture shows that i need a 16mm spacer for this 77’ A3 swingarm.
Just thought i’d pass some
info on from my findings as I haven’t found a ton on this in the past.... After I run to the hardware store tomorrow I can hop on my bike and roll away in style.
Cheers!
This would be great in the wiki!
That’s where it’s goin!
Hey they make a green bearing locker just for stuff like this.
Good to know- The High strength Loctite seems to be holding up just fine over the big potholes in New England.
I’ll be posting this article to the wiki when I have some more spare time.
