Re: Garelli gran sport kit build problems.
Joel Mojica /
So guys thanks for the help I got the bitch running. So first we made a home made leak down test and found a leak from the spark plug, reed block, fix it with some gasket dressing sealed up nice did the same with the head and no more leaks. The timing is set on1.6mm btdc
And I’m reaching temp over 400 degrees. Breaking it in with a 80 jet at the moment. Will update with a video of me running it. Thanks for all the insight.
