Re: Garelli gran sport kit build problems.
Stephen Simmons /
> Joel Mojica Wrote:
> How did you get the head to seal with the gasket ?
You have to snug the bolts up then tighten then evenly. And yes you must use a head gasket on the NOI. Also I run my timing 1.8mm btdc but 1.6mm btdc will let it run a little cooler. (edited)
