Re: Garelli gran sport kit build problems.
Tri-ped Dave /
The point gap should be the same. You might want to advance the timing ever so slightly for the expected higher rpm. Beware to advance too far since this can cause excessive heat. You will already have that as a possibility with a higher compression head. I try and avoid too much compression because of the heat factor. I build mine to last, not to race. if this were my build, I would run a gasket if only to reduce the comp slightly to increase longevity
