Garelli gran sport kit build problems.
J Prez /
What’s up guys new here to moped army and need your help on my first project any insight appreciated. I bought the 70cc noi malossi reed valve kit and Installed it. I’m running stock timing. 16mm Sha. Polini senior shitter pipe.
Stock air box I Also have a malossi high flow air breather. Brn 70cc head custom cut for the malossi kit. I did match the to the transfers of the case or I did my best. My compression test hit 180psi is this normal ? next issue is the head doesn’t seal. Can I run the head without a head gasket?
Where should I set my timing, spark plug and points gap?
