Re: 1989? Jawa 210 sport
Frank Bailey /
Buy these:
https://www.treatland.tv/treats-puch-15mm-bing-intake-p/number-one-grandpa.htm
https://www.treatland.tv/SHA-15mm-runtong-clone-carburetor-lever-choke-p/sha-15mm-runtong-carb-lever.htm
You will need to make a shim out of 1MM thickness stock. I used copper sheet because it's what I had on hand. Some have used milk jug plastic. The puch intake is 20MM OD and the Dellorto clone carb without it's crappy shim is 22MM ID. A Viton O ring would best be used to complete the seal. Then file the mounting holes in the intake and either make a Pergo flooring spacer to bolt it to the cylinder or just grind off the edges to fit with a gasket. If you can, the Pergo flooring spacer is sweet!
A 62 or so jet would be a good place to start. I think an unlabeled 68 comes with that carb. It will be too rich.
  1989? Jawa 210 sportTopic by: Eric Butterfield Eric Butterfield 08/03/19 03:34PM
  Re: 1989? Jawa 210 sportRe: P D P D 08/03/19 06:13PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/03/19 06:17PM
  Re: 1989? Jawa 210 sportRe: Stephen Keller Stephen Keller 08/03/19 08:20PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/03/19 10:25PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/04/19 08:39AM
  Re: 1989? Jawa 210 sportRe: Stephen Keller Stephen Keller 08/04/19 11:29PM
  Re: 1989? Jawa 210 sportRe: live ɘvil live ɘvil 08/05/19 01:23AM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/05/19 09:12AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/05/19 11:23AM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/07/19 03:18PM
  Re: 1989? Jawa 210 sportRe: Born to be WillD Born to be WillD 08/07/19 04:54PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/07/19 05:44PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/08/19 10:52AM
  Re: 1989? Jawa 210 sportRe: P D P D 08/08/19 11:32AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 02:43PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/08/19 04:15PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 04:57PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 05:02PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/09/19 10:03AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/09/19 12:39PM
  Re: 1989? Jawa 210 sportRe: Max Ginsburg Max Ginsburg 08/13/19 04:40PM
  Re: 1989? Jawa 210 sportRe: live ɘvil live ɘvil 08/21/19 01:09PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 02:18PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/21/19 02:35PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 04:39PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 01:05PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 01:07PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/23/19 01:58PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/23/19 05:26PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/03/19 03:45PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/03/19 08:28PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/24/19 10:31AM
  Re: 1989? Jawa 210 sportRe: P D P D 09/24/19 10:41AM
