Re: 1989? Jawa 210 sport
Eric Butterfield /
Thanks Frank & Born to be wild. Those are both great sources. I'd not looked at the stuff under the technical tab yet on jawamoped.com. And Frank, that is exactly what i was after for the intake/carb detail.
I took apart the carb one last time and cleaned it completely with carb cleaner, compressed air & copper wire. Got the same results. still leaks gas as the needle valve isn't airtight. Bike only starts on full choke, engine seems to race as if at WOT, then dies off after 4 or 5 seconds. If i try to work the throttle, it dies immediately. With the carb completely cleaned, i was expecting to at least get the thing to idle. Any suggestions?
Also took apart the petcock and the little cork disc with the holes had started to disintegrate, so I'll need a new one of those to get that right.
was probably a bit too optimistic about getting this thing on the road right away. When i bought my 79 qt50, I pulled & cleaned the carb, petcock & gas tank. Changed the oil and put in a new spark plug and it's been up and running great ever since.
  1989? Jawa 210 sportTopic by: Eric Butterfield Eric Butterfield 08/03/19 03:34PM
  Re: 1989? Jawa 210 sportRe: P D P D 08/03/19 06:13PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/03/19 06:17PM
  Re: 1989? Jawa 210 sportRe: Stephen Keller Stephen Keller 08/03/19 08:20PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/03/19 10:25PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/04/19 08:39AM
  Re: 1989? Jawa 210 sportRe: Stephen Keller Stephen Keller 08/04/19 11:29PM
  Re: 1989? Jawa 210 sportRe: live ɘvil live ɘvil 08/05/19 01:23AM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/05/19 09:12AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/05/19 11:23AM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/07/19 03:18PM
  Re: 1989? Jawa 210 sportRe: Born to be WillD Born to be WillD 08/07/19 04:54PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/07/19 05:44PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/08/19 10:52AM
  Re: 1989? Jawa 210 sportRe: P D P D 08/08/19 11:32AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 02:43PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/08/19 04:15PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 04:57PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/08/19 05:02PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/09/19 10:03AM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/09/19 12:39PM
  Re: 1989? Jawa 210 sportRe: Max Ginsburg Max Ginsburg 08/13/19 04:40PM
  Re: 1989? Jawa 210 sportRe: live ɘvil live ɘvil 08/21/19 01:09PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 02:18PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/21/19 02:35PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 04:39PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 01:05PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/21/19 01:07PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 08/23/19 01:58PM
  Re: 1989? Jawa 210 sportRe: Frank Bailey Frank Bailey 08/23/19 05:26PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/03/19 03:45PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/03/19 08:28PM
  Re: 1989? Jawa 210 sportRe: Eric Butterfield Eric Butterfield 09/24/19 10:31AM
  Re: 1989? Jawa 210 sportRe: P D P D 09/24/19 10:41AM
