Minarelli V1 Oil?
Anyone know what type of oil I should use for a Minarelli V1 engine?
Re: Minarelli V1 Oil?
ND 20 or ND 30
I have been running ND30
If you don’t mind buying a two gallon jug, you can get ND 20 at tractor supply. I have several V1 bikes, so buying oil in bulk is not an issue for me.
Josiah Radebaugh /
I've run 30w non-detergent.
🇮🇹💦 Of the Loin /
20w-50
I put ND 30 in my Morini, can you REALLY tell the difference between 20 and 30?
I have found that In the winter it’s harder to pedal start the one with the heavier oil.
Benjamin The Wandering Pacer /
> and 30?
What Larry said. ND 30 is fine, I just find it a bit thick at the start. Once the engine warms up it should run fine.
