Re: Pacer SS
Ok I did some research and according to three different parts books, M1 motors came with a 13 front sprocket.
M01- 12 or 13 front- 20mph & 25mph versions.
M02- 13 front
All had either a 28 or 40 rear sprocket. No refference to any sizes in between. My rear does says "Z32" which is typical on any Italian sprocket.
I did find it interesting that there was a 7 spoke mag wheel option. Same sprocket sizes as wire spoke too. I have no doubts that they were also 16s and probably the exact same wheels thats on this other Italian bike:
(edited)
Re: Pacer SS
So in retrospect, the new SS that I had as a kid would have been faster than most on top end because of a 28 rear sprocket. No doubt that anyone who has trouble breaking 30 mph on an otherwise stock machine has a somewhat larger rear sprocket.
Re: Pacer SS
. Chudas. /
Yeah I think according to Myrons, there were different versions of the SS, I think i have the mid speed (25mph) one cause it had a pretty big rear sprocket,
when i changed the sprocket it hit 30, then i added the pipe, upjet, 33, changed the clutch springs, which helped the take off.then i put those fancy MLM block and reeds which let it breathe more, upjet and hit 35
still has a stock intake and carb, which Im planning to upgrade next season, then fine tune everything.
Re: Pacer SS
> rear sprocket,
I checked the carb on mine and its got a 52. Thats the magic number for Dellorto 14.12 carbs on 50cc 2strokes. I upjeted from 52 to 60 on a Garelli noi motor and picked up 2-3 mph. It four stroked on 62 so 60 is as big as it goes for now. I did remove the two tubes inside the airbox though. Idle and low speed seemed a bit rich until I dropped one of these custom slides into the carb. Night/day difference because it lets in more air to lean out overly rich bottom end with a 60 main jet installed. Need to grab a couple more.....
Custom Del sha slides
Re: Pacer SS
. Chudas. /
Oh awesome! I have a two 14.12s coming that i bought here along with a 15.15, I read that i can sand an incline on the slide to make it leaner in a thread.
I believe Im at a 62 right now.
Thanks for the info!
Re: Pacer SS
The 40T and more should be Minarelli powered. 34T standard for M1 and 26-28T for MO2. But that's on Sebrings.
Re: Pacer SS
Thank you Don.
Here is what the book of Pacer says, Part #30 and 47 respectively:
Re: Pacer SS
With a small 16" wheel, feel free to reduce that silly 40T sprocket to 34 on the M1 and 26 on the MO2. I run a 24T with an MO2 and 17" wheels.
That is UNLESS you LOVE climbing hills slowly, or weigh over 300 lbs.
Re: Pacer SS
Wow, the non top tank models look a lot like the LEM models the hardware store sold when I was growing up, any relation? LEM had mag wheels though.
Re: Pacer SS
Ive considered wheel size since day one of getting back into these money pits, and quite frankly 16" is way more common on all the Italians. I have a factory spoked 17" wheeled 2 speed noi. It even checks out with this chart by vin#. How often you see 17" wire spokes?
(edited)
Re: Pacer SS
I had a Cosmo Colt II (MO2 engine)with 16" spoked wheels and if I hadn't traded it, the rear sprocket would've been downsized to 26 teeth or maybe even 24T...….preferably also changed to mags.
You hardly ever need 40+ teeth except on a Minarelli powered,because the engine to trans ratio is way higher on the Minarelli V1.
I see a Minarelli powered Pacer in PHOTO section, but I assume the engine bracket was changed for that engine by owner.
Re: Pacer SS
Benjamin The Wandering Pacer /
You are correct Don, the Pacer brand only came with Morini. There are a number of people who have engine swapped for a Minarelli. I cry a little every time I see one but that's how it is with with mopeds. ::::( I will admit I also did an engine swap but! It was still a Morini!! (M101) :D
Re: Pacer SS
I always switch the M1 over to MO2. I just don't like single-speed mopeds down here in the rolling hills. Plus the MO2 takes off WAY quicker from a dead stop at a light.
Re: Pacer SS
. Chudas. /
I have 33 teeth on the rear as I didnt wanna sacrifice take off, but with blue springs it pepped up off the line, I put on the 15.15 and Im getting a little gurgley at the bottom end, I have a #2 slide in, which has a incline, I also have a #1 with a flat bottom.
Its still ripping pretty good with a 64 jet in there. Havent plug chopped though.
Its 40 degrees here right now and boy was that ND30 gummy in there.
Re: Pacer SS
> chopped though.
Yeah ND30 is like that! Which is why need need to petition makes to bring back ND20. ::::(
Re: Pacer SS
. Chudas. /
Yessir!! Hey Pacer, does your carb ever get oily? like everytime I take off my air filter, I have one of those freeflows from Treats, it has like a teaspoon of oil in there.
Re: Pacer SS
Here's 2 gallon at Rural King in 20W ND..... 25.00 for 2 gallons.
https://www.ruralking.com/oil-harvest-king-20wt-n-d-2gal
Re: Pacer SS
>Yessir!! Hey Pacer, does your carb ever get oily? like everytime I take off my air filter, I >have one of those freeflows from Treats, it has like a teaspoon of oil in there.
Yes, That is normal from the fuel.
Thanks Don. I'll have to jump on that. :D
Re: Pacer SS
Yes, I think MopedLar mentioned TSC or Farm and Fleet also had the 2 gal. in 20W.
Re: Pacer SS
Gotta keep the Pacer SS thread going.
Shout out to Dave @ Moped Junkyard for digging up and coming through. I'm pleased with the last set of N.O.S. front forks with cones, cups, bearings, bar clamp and steering stem nut/washers. Love the nice unbeat rear stainless fender too. Pedal shaft seals are not easy to find either.
(edited)
Re: Pacer SS
> either.
Nice score! I got his last Pacer seat. Was marked as an SS seat but turned out to be a Pacer LS seat. So I am going to make one of my project bikes into the LS model. :D
Re: Pacer SS
> either.
it'll be nice to see pics when you get it together....
Re: Pacer SS
> unbeat
> > either.
Thanks...it'll be nice when I can lay my hands on a fuel tank.
Re: Pacer SS
. Chudas. /
I got that Hurret speedo for you too man, Ill throw in the bars for free, so you can frankenstein one together
Re: Pacer SS
> unbeat
> > either.
So is that a deluxe?
Re: Pacer SS
Correct! Below is from the flyer I have on my site. :D
Re: Pacer SS
This thread is too young to die. Here's a little something to perk it up. Wink Wink. :D
Pacer Super Sport Mug
Re: Pacer SS
I'd take one with the horse head logo on both sides.^^
Re: Pacer SS
Done. ;) https://www.thewanderingpacer.com/product/pacer-logo/
Re: Pacer SS
Damn that was fast. Did you already have these made and I just didnt see them?
