Crank seal gear problem
Terry Dorman /
So I was trying to change my crank seal and noticed the gears are a bit lose. There was what appears to be a broken clip or ring of some sort inside the clutch case. Des anyone know where it goes and what part number it is? Also how to remove the other clutch wheel because the one on the outside has no cork left.
