Crank seal gear problem
So I was trying to change my crank seal and noticed the gears are a bit lose. There was what appears to be a broken clip or ring of some sort inside the clutch case. Des anyone know where it goes and what part number it is? Also how to remove the other clutch wheel because the one on the outside has no cork left.
Re: Crank seal gear problem
https://www.treatland.tv/original-OEM-tomos-sprag-clip-for-A35-p/tomos-sprag-clip-a35.htm
A35/55 are the same. A3 is different. It goes on the back of the gear cluster on the gear where the inner pedal chain hooks to. Hooks to this gear.
https://www.treatland.tv/tomos-OEM-starter-assembly-cage-p/tomos-oem-starter-gear-222209.htm (edited)
this ones obvious but it may help to state your moped, or take pictures of what your having issues with.
take a look at pictures of a35/a55 clutch bells. once u take the nut off it all slides out, may have to tap a little n pay attention to all washers/shims.
Sorry I tried attaching photos and videos 5 times didn't seem to work
It's a 2001 Tomos Sprint.
Following
The clip goes on the back side of this gear on the gear in the red circle. One end goes in the hole where the yellow line is and the other end locks behind the silver pin in the red circle. Makes sense?
