Hero Puch parts
Anyone know good source for hero Puch parts. Can't find anything online
Re: Hero Puch parts
Might try the Buy/Sell section here .
https://mopedarmy.com/forums/list.php?2
Re: Hero Puch parts
Mat Ewers /
Na nothing there after new parts
Re: Hero Puch parts
Check with these guys. They have Handy Bikes old inventory if I'm not mistaken.
https://www.doscycles.com/search?type=product&q=hero+puch
Re: Hero Puch parts
some puch hero parts are interchangeable with other bikes. what are you looking for?
Re: Hero Puch parts
Mat Ewers /
Clutch and brake parts
Re: Hero Puch parts
you might be able to use regular puch parts. ZA clutch and if its brake shoes your after you could use the stuff from five star wheels.
Re: Hero Puch parts
Mat Ewers /
What it looks like
Re: Hero Puch parts
Honestly? Check out some of the Indian fb groups. That's probably going to be the best place. Time to learn Hindi.
Re: Hero Puch parts
Mat Ewers /
Honestly what?
Re: Hero Puch parts
Re: Hero Puch parts
Re: Hero Puch parts
todd amundson /
That clutch is splined in the middle. If you replace the crank with a Z50 2 speed it will work in there. Just get new shoes. That clutch is basically a Minarelli 2 shoe. These pads fit.
https://www.treatland.tv/NOS-original-minarelli-V1-clutch-pads-w-tension-s-p/nos-v1-clutch-pads-with-bits.htm
Also, since the bell is just right, you can adapt a KTM 50 clutch to fit the end of the crank. I have done this but it requires a bunch of machine work.
Re: Hero Puch parts
great infoTodd! anybody have a lead on the plastic engine covers hook it up.
Re: Hero Puch parts
todd amundson /
No, your'e fucked
Re: Hero Puch parts
i figured.
Re: Hero Puch parts
DrGeorgeTompson (Alan) /
Clutch shoes are same as V1. Brake shoes are same as Mb5 rear
https://www.treatland.tv/ProductDetails.asp?ProductCode=groovy-pads-10860-110x25
Re: Hero Puch parts
Mat Ewers /
> machine work.
Thanks for that. Any more information on the ktm clutch. Alot cheaper and easier to source where I live
Re: Hero Puch parts
What's wrong with your clutch?
also, how slow is that thing? Mine is slow as shit. I feel like it shouldn't be. (pickup wise at least)
Re: Hero Puch parts
Mat Ewers /
Slow as feel like clutch engages way to early so was gona mod old one or try to at least
Re: Hero Puch parts
> try to at least
Nice! same.
I just put stiffer springs in mine and it's a little better. Could probably go a little stiffer as it's still kinda hard to get out of the hole and into the powerband, espescially on a hill.
I am debating adding another base gasket and lowering the exhaust port floor to squeeze some more ass out of it.
Re: Hero Puch parts
todd amundson /
> DrGeorgeTompson (Alan) Wrote:
> or
> > try to at least
> Nice! same.
The hero seems to be based way off and take a lot of work to get the port timing right. My trike has a OEM Hero cylinder and I had to deck the jug a bunch for it to fly on an E50 case. My Hero motor that’s modified now runs a Treat’s 70cc piston in the stock jug. I had to mill 2.75 mm off the base sealing surface of the barrel and deck it another 2mm off the top. I swear the Hero rod length is longer than a E50! So much work but at least pistons are under $40.
