I just bought a 2017 wolf moped off craigslist. It runs great. The old owner did'nt have a battery in it so you had to kick start it to get it going. They key was also missing. It was actually his. His family was out there giving it away to me. Anyway he wired it so you don't need a key and you just kick start it. I just got a new battery and tried to start it with the ignition button and it wont' work. Do i have to do something else to hook the battery up. If someone could help I would really appreciate it thx!
Wolf 2017 Scooter - simple question
Re: Wolf 2017 Scooter - simple question
They have a free service manual for your wolf rx50 and they are all about helping ya get your scooter back on the road. It is likely a simple fix and I wish ya the best of luck!!
The starter button probably runs through the key switch.
Just imagine being able to easily flag this to be moved to a "Scooters" forum.
Not that the traffic here is anywhere near heavy but ad space is ad space
Plus, eventually the kids with the crappy scoots will most either learn and upgrade to a vintage scoot, noped, or maybe even jump into 'peds.
This guy posted with a Tomos moped 4 yrs. ago, and SHOULD know to post in the OFF-TOPIC at least.
Thanks !
power only gets to the starter button when 1) the key is switched to [on], 2) the killswitch is set to "run" and 3) the brake lever is held down (prevent you from starting it with throttle accidentally open and it just taking off)
Anyway sounds like you'd just need to bypass the starter button to just go straight from battery to button and back to the starter relay. you can always jumper cable the starter direct from the battery to see if it works, like bypass the relay to check the starter function.
thank you !
So i should bypass the starter button? but if I bypass the starter button wont' it not work?
He meant bypass the ignition I think, not the starter button. Look at the wiring diagram and try to figure out how to connector the starter button circuit without the ignition. Or buy a new ignition/key.
