Basic adjustment help Peugeot 103
Matthew Shapiro /
Hey guys,
I recently picked up a Peugeot 103 and put new cables/housing, new carb, fuel line and filter, spark plug... basic stuff, got the bike running and can drive it around the neighborhood pretty consistently but as soon as it goes too slow the motor will stop running. I can also get it running and idling on the kickstand with the rear wheel off the ground, but cannot get the bike to idle without the clutch engaged and the rear wheel spinning. is this a motor tension adjustment? or a carb adjustment? something entirely different? thanks
Re: Basic adjustment help Peugeot 103
https://www.mopedarmy.com/wiki/Sticking_stock_clutch_remidies_for_Peugeot_103
also make sure it isn't just running away off the idle circuit - you can pull the belt off to do some idle speed testing before you get into it with the clutch.
I would be looking at the clutch possibly sticking and not releasing, may be full of crud in there, if its on its stand and you apply the rear brake does it kill the engine, if so could be the clutch.
sounds like its idling fine but clutch still engaged, its not a hard job to remove the clutch but it HAS to go back correctly, you need a guide as it could be assembled incorrectly at the moment.
look here and review cheetachromes guide for the clutch
https://www.mopedarmy.com/wiki/Peugeot_103_stock_clutch/variator_assembly_by_Cheetahchrome
also the wiki is a good page to get your head around how the various parts work. happy reading!!
https://www.mopedarmy.com/wiki/Category:Peugeot
here is a very good .pdf Peugeot user/workshop manual I use lots
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwj27bf07cfjAhXqVRUIHfzCBYcQFjAAegQIABAC&url=https%3A%2F%2Fvintagemopeds.files.wordpress.com%2F2013%2F01%2Fpeugeot-103-clymer-manual.pdf&usg=AOvVaw0PsUGkx7ybEKipSN1ayiZV
Simon
u.k
1979 Peugeot 103 stock
If bet money that your clutch is frozen.
Hi Matthew - did you ever solve this issue? I'm having the same one. Thanks!
