MOPED KEEPS DYING OUT ON ME
What is wrong with my 1986 Honda Spree if whenever I ride around it runs fine but then I get to a stop sign and then the engine quits on me if I just let it idle! Is there some way to fix this or do I need a tune-up?!
Re: MOPED KEEPS DYING OUT ON ME
try screwing around with the carb screw. lol . go around the block a couple of times and test it then do that untill you can idle the way you want.
That happens to me too. If I throttle it too fast from a complete stop, then the engine quits on me. It just started doing this to me too. I have a 1993 Tomos Sprint.
-Viet
try playing with the carb screw then if all else fails try pincing the gas line a little bit so the gas flows slower.
Try going to a colder plug, remember its summer time and heat will kill a 2-stoke engine.
How do i clean out the carb on a '93 tomos sprint?
-Viet
