Re: Race Bike Build - Oct 12th/13th due date
> Lawrence Au Wrote:
> Pick up this book if you can.
> Suspension in my opinion is one of the most important parts of setting
> up a race bike. Before any performance modifications etc. a bike needs
> to be set up for the individual rider.
> In all the racing series I'm in, what wins races is suspension since
> most of the riders are all within a 2-3 seconds of each other in lap
> times and skill. The bikes are for the most part all pretty equal in
> power. Comes down to setup and style the rider can be fastest and
> comfortable at.
> I was building up my Derbi for Cherry Valley, so lets meet up at the
> next race after this one. Also, feel free if you're ever in Brooklyn to
> hit me up and come have a beer at my shop.
> Larry -
Hey larry i just ordered that off amazon. Looks good.
I dont think im at the skill level to be prioritizing suspension; my goals are body positioning and throttle control through corners.
I may be in ny for work in nov. Ill shoot you a pm
suspension and tires are priority 1 at any skill level
I got fresh k56 heidenaus and will be playing with fork fluid weights
I'm not too concerned about moped suspension on a smooth track with sub 50mph speeds. My bike's rigid, front and rear. But whatever helps you, go for it.
You definitely don't want to be riding a spongy bike with a lot of brake dive in the front, tho...
EVER .
Toooooo dooooooo
mocked up rearsets after draining and replacing the clutch.
It had a 3 shoe with blue springs. Running a v1 jammer now.
Anyone holding onto replacement shoes?
Done
> 50mph speeds.
You should be, cornering and braking compress the suspension accelerating and coming out of cornering unloads the suspension. something has to give under that force and if it's not suspension it's the contact patch of the tire lol. The relative smoothness of the surface isn't really the issue.
I may come to this any one have Morini parts? Or engine? M1?
I have raced here a dozen times or so and what I took away was great clutch work that hits early and great brakes and a early hitting pipe! For the turns and the corners the straight away is up hill so 50mph is about it for top speed. The variated boys and girls are slightly superior on this track so beware. It’s cold here also and humidity is a strange factor.
> strange factor.
Hmm whats the jetting change this time of year?
Converted the tomos ebr to puch races and used a few spacers. 21 ball bearings.
The footpegs are good but need a 3rd point of contact for sturdiness.
Tomorrow is tightening up the exhaust and test rides. I need to dial in the clutch.
Great !
Cleaned up the wiring. Soldered all cable ends after shortening. Rearranged the box. Also sleeved all exposed wiring.
Are you using a tomos cdi?
I sure am. I got an hpi but i have the wrong e50 cases.
Got a lot done tonight.
-baffle brace
-built a new hydraulic brake cable, bled, installed. Now can endo.
-registration sticker mount
So i took my flywheel nut off to install my pullstart panel.
Now the bike runs backwards.
Better quality hoses and temp installed.
Trail tech tomorrow.
what are you using for coolant?
Johnnie Distefano /
Good work so far! This thread is great
Any recommendations? I was discussing this at the shop. Im running distilled water right now, and my head temp is PEAKING at 286 Fahrenheit.
That led me down the performance oil rabbit-hole, plug heat, and coolant options.
My main lingering question is: whats optimum operating temp for the cylinder?
I do have an EGT that will be on the bike eventually for more tuning and experimenting..(edited)
Thanks! I cant thank the guys enough for helping me along the way.
i like maxima products so i use the Cool-Aide, but just wanted to ensure that you weren't planning on running regular antifreeze on the track.
Yea I was just going to run a hotter plug and distilled water
You can try water wetter
Series of ups and downs tonight. 5 more hours wrenching. Found a leak after blowing through the tank when welding a tab on. High risk and it smoked me.
New top speed though. Had some good hot laps tonight. Down gearing tomorrow and tuning clutch.
Prioritizing for tomorrows last wrenching day.
1. Plug pinhole
2. Adjust seat and bars
3. Reduce rake
4. Install damper
5. Clean and oil chain
6. Install hotter plug
7. Run water wetter
8. Clean carb, upjet
9. Inspect clutch
10. Seat time
♣Slew Foot♣ /
Good luck man...
Good luck!
Pics to be posted tomorrow! Got 2nd place in non-variated and 3rd in unlimited. What a great trip with a ton of help from rad people.
I cracked and bent my clutch bell, which threw the clutch plate retaining spring BEHIND the clutch.
Lucky for me a friend sacrificed/lent me their entire clutch setup so i could run my race.(edited)
