Re: Which one to build, E50, ZA50 or 103SP?
Rebel Moby /
Ball connection will always weep, when the weep becomes more of a messy leak it is telling you that it is time for a exhause cleaning...
...sticky throttle - if you have a SHA installed then route the cable NOT inside the spring but cable first then assemble to the spring and install so the spring does not bind on the cable.
> Ryan Graeme Wrote:
> The problem is, they all ran when I bought them! The ZA50 was a concious
> strip down, I was new to mopeds and got all excited. The E50 was to use
> as a runner whilst the ZA50 was getting done, but then I messed with it
> and lost momentum! I am swaying towards just going back over the E50 and
> getting it road ready and jetted right. The peugeot was running, albeit
> with the sticky throttle and it rips too. The peugeot was meant to be a
> run around whilst the ZA50 and E50 were out of action. The peugeot also
> has a leaky black stuff situation at the ball joint spring part of the
> exhaust, but I assume that is normal as that is a pivot point and cannot
> seal properly. Puchs are fairly non existant in France, so would be a
> novelty factor for some of the locals. There is a group of 3 or 4
> motobecanes that go past my house every now and again, but I'm always
> too late to wave them down.
