Re: Compression Testing Issues
matt madden /
I have a cheap compression tester too (not HF)...the schrader valve quit after about 5 uses...bought the correct valve for another tester and installed...I also use the hose and get pretty regular 100-125psi on my bikes...
the valve is at the end of the hose that attaches to the spark plug hole so i don't think it impacts the readings
