Re: Compression Testing Issues
> Les B. Wrote:
> Just used the loaner program this morning..Got a bearing splitter...took
> a half hour .. took it back , my refund. Worked out good. The freezer
> method didn't work out.
Installing the bearing with the freezer works fine for me. I don’t even need to freeze the crank , I just put the the bearing in the over set it to 220 and check on them with a temp gun.
