Re: Flasher problem
Rebel Moby /
Flashers - power goes to the flasher unit, from the unit it goes to the left-right direction switch, when you switch to RIGHT it directs the power to the right flasher lights which completes the circuit and the flasher unit will make the right lights flash, when you switch to LEFT it directs the power to the left flasher lights which completes the circuit and the flasher unit will make the left lights flash.
