Re: Is there any way to stop a motobecane at a stop sign or light while running
Rebel Moby /
That is the magneto side of the motor. Thread of the Novi nut is left hand so you have to turn it clockwise to loosen using a 3/8 drive breaker bar. Put a #72 hose clamp around the flywheel with its nut at 3 oclock and cut a piece of 2x4 long enough to go from nut to the floor. That will stop the flywheel from turning as you loose the nut.
You will need a clutch/flywheel puller to adjust the timing though to take the cam off the crank... if that is what you are attempting...
  Is there any way to stop a motobecane at a stop sign or light while runningTopic by: Austin Saunders Austin Saunders 07/08/19 03:26PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Stephen Keller Stephen Keller 07/08/19 03:29PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Probably Fred Probably Fred 07/08/19 04:58PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Probably Fred Probably Fred 07/08/19 03:32PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: live ɘvil live ɘvil 07/08/19 03:48PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Born to be WillD Born to be WillD 07/08/19 04:20PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Rebel Moby Rebel Moby 07/08/19 05:39PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Ryan Graeme Ryan Graeme 07/08/19 11:44PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Stephen Keller Stephen Keller 07/09/19 01:01AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Austin Saunders Austin Saunders 07/08/19 07:38PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Rebel Moby Rebel Moby 07/08/19 08:59PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Austin Saunders Austin Saunders 07/08/19 09:15PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Rebel Moby Rebel Moby 07/09/19 09:50PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: pat splat pat splat 07/08/19 07:43PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Bruce Zapper Bruce Zapper 07/08/19 07:51PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Austin Saunders Austin Saunders 07/08/19 08:59PM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: kenny s kenny s 07/09/19 07:06AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Aaron Blair Aaron Blair 07/09/19 08:14AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Austin Saunders Austin Saunders 07/09/19 09:42AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Bad Cadillac™ Bad Cadillac™ 07/09/19 09:00AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Dirty30 Dillon Dirty30 Dillon 07/09/19 09:57AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: Don Ohio Don Ohio 07/09/19 10:00AM
  Re: Is there any way to stop a motobecane at a stop sign or light while runningRe: live ɘvil live ɘvil 07/09/19 03:50PM
