Re: 1957 Peugeot
LGN Bruiser /
Trying to think of anything useful to tell you.
You can find the taillight assembly on french ebay if you are vigilante. Should be a catalux 7 by Sobities.
The handlebar levers are kept at an awkward angle with pins. You can drill new holes for the pins so the levers are more comfortable.
If you still have plastic needle bearings in the clutch and driven pulley, its easy to swap for modern caged needle bearings.
Bearings and seals in the engine are the same as 102, 103 bearings and seals.
Got a new belt at the local tractor supply.
Thats sick you still have the covers. Wax and claybar will bring a lot of that blue back.
  1957 PeugeotTopic by: reddy kilowatt reddy kilowatt 07/07/19 07:07AM
  Re: 1957 PeugeotRe: Stephen Simmons Stephen Simmons 07/07/19 08:39AM
  Re: 1957 PeugeotRe: reddy kilowatt reddy kilowatt 07/07/19 09:02AM
  Re: 1957 PeugeotRe: Bas Autowas Bas Autowas 07/07/19 09:10AM
  Re: 1957 PeugeotRe: reddy kilowatt reddy kilowatt 07/07/19 09:16AM
  Re: 1957 PeugeotRe: Rebel Moby Rebel Moby 07/07/19 05:30PM
  Re: 1957 PeugeotRe: reddy kilowatt reddy kilowatt 07/12/19 07:42PM
  Re: 1957 PeugeotRe: Andrew Squiggman Andrew Squiggman 07/12/19 09:39PM
  Re: 1957 PeugeotRe: Bob Naske Bob Naske 07/13/19 06:15AM
  Re: 1957 PeugeotRe: reddy kilowatt reddy kilowatt 07/13/19 07:25AM
  Re: 1957 PeugeotRe: Rebel Moby Rebel Moby 07/13/19 09:27AM
  Re: 1957 PeugeotRe: jumpsuit steve jumpsuit steve 07/13/19 08:33AM
  Re: 1957 PeugeotRe: reddy kilowatt reddy kilowatt 07/13/19 11:53AM
  Re: 1957 PeugeotRe: Rebel Moby Rebel Moby 07/13/19 05:56PM
  Re: 1957 PeugeotRe: Albert Dyer Albert Dyer 01/14/21 01:01PM
  Re: 1957 PeugeotRe: LGN Bruiser LGN Bruiser 01/14/21 01:53PM
  Re: 1957 PeugeotRe: LGN Bruiser LGN Bruiser 01/14/21 02:07PM
  Re: 1957 PeugeotRe: Albert Dyer Albert Dyer 01/17/21 10:13AM
  Re: 1957 PeugeotRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/15/21 09:10AM
  Re: 1957 PeugeotRe: Nile Muti Nile Muti 01/15/21 12:28PM
  Re: 1957 PeugeotRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/17/21 05:22AM
  Re: 1957 PeugeotRe: Aaron Blair Aaron Blair 01/17/21 07:55AM
