Re: Puch E50 points stator plate
Ken really doesn’t like those black box ignition coil and I can finally see why.
When those black boxes get to hot they start to melt. Iv ruined multiple flywheels doing this. Also they fit a lot tighter then stock so your flywheel clearance sucks.
Stock igtions setups are just as easy if not easier to set up and you actually can seal the magneto wire port with the stock rubber plug so no fucking dust stones get inside the flywheel and scratch it.
I will never buy a black box again.
Thank you ken, sorry it only took my like three years to notice the stock ignition set up is way better. (edited)
