Batavus VA Bronco Rear Shock Length
Anyone know what the correct rear shock length was on the Bronco.
Thanks
Re: Batavus VA Bronco Rear Shock Length
HandsomeSteve ;) /
Anyone?
Can't you measure what's on there now ?
According to Myron's , both the regular and the HS use 300 mm shocks 10 mm eyes .
HandsomeSteve ;) /
If that was the situation I would have measured them.
You don't need shocks to make a measurement .
You could simply position the bike how you want it when new shocks are mounted and then measure .
Hey Steve, I can measure the ones on my bronco tmw for ya!
HandsomeSteve ;) /
Thanks bud.
Andrew Squiggman /
Pd fails again
> Andrew Squiggman Wrote:
> Pd fails again
It wasn't me that failed . ;)
i have a bronco in my garage. still need those dims?
Mine are 310s and do appear to be stock! Hope that helps duder!
HandsomeSteve ;) /
Thanks. I will look for some 310mm.
And most likely will have to settle for 320mm
