AV10 Stock Jetting w/Dellorto 15.15 SHA?
Adam Margovic /
Hi all,
I've never had an AV10 before. Does anyone know a decent ballpark for jetting a bone stock rebuilt AV10 with a Dellorto 15.15 SHA? I have #58-72 jets from my last order from Treats. I'll definitely start high and plug chop, but I literally have no idea where to even start and don't want to mess up a fresh cylinder.
Here in PA, my stock AV7 ended up using a #58 jet in the Dellorto, but I assume the AV10 would need a significantly higher jet having reed valves, etc?
Re: AV10 Stock Jetting w/Dellorto 15.15 SHA?
#52 to 56.
#58 should be really rich on a stock with no special pipe.
every bike is different, just start high
Russell Huddy /
> Don Ohio Wrote:
> #52 to 56.
That’s for av7. Av10 I’d start at around a 68
That's right, and thank you Russell. Not gonna get 150 mpgs with THAT engine are ya?
Yep - 66 thru 70 for stock AV10 depending on the version
Adam Margovic /
Thank you folks! I was leaning towards that range, but it always feels better to hear it from someone else as well!!
