Re: Bike Bug fuel line help needed
Mark Booth /
I had 2 of these motors. I looked at the web site that I used to get a Priming Bulb but the site can not be reached... Weird.
So the tank does not need to be pressure tight. In fact it needs to be vented. I have attached a photo of a tank with the OEM bulb on it. That line goes to the Fuel Pump on the bottom of the engine. From there it goes to the carb. It then fills the carb with fuel and it over flows back to the gas tank through the ½ inch line. If the brass tube comes out of the carb or Fuel Pump use loc-tite to reattach it.
Hope this helps.
[attachment 201734 P1010009.JPG]
