Bike Bug fuel line help needed
Doug Hammond /
I got an old Bike Bug for $25 and have had it running. I dont understand the correct running of the fuel lines.
#1 Tank is missing gromit and line. There is just a 1/2" hole or so. Where will this line go? Does gromit need to hold vaume/pressure?
#2 I will need a priming bulb inline somewhere. Where should this be placed?
#3 I see there are arrows on fuel pump. How does this relate to running lines?
#4 There is a large line conector on carb. Is this for unused fuel sent to carb from pump and will trikel back into tank (through gomit that is missing?)
#5 The best solution I saw for drive wheel is two layers of radiator hose. I know about the skateboard wheel concept but there is no info regarding how to connect it to shaft. Any Ideas?
Thanks,
Doug Hammond
