Re: Hobbit simple carb + setup for DR head
Ronald King /
> Jackerz ! Wrote:
> If your putting a dr kit on I’d 100% for sure put a new crank in. I’ve
> seen a few snap that used the stock crank and kit combo and the variator
> and clutch bell took off never to be seen from again. Save yourself the
> pain and do it right the first time. Also the dr is A great choice for
> your hobbit! If you don’t want to fuss with the stock carb I really like
> this setup on dr
> https://www.treatland.tv/honda-hobbit-carb-UPGRADE-pack-vm20-p/hobbit-carb-pack-vm20.htm
> Makes jetting a breeze on hobbits!
I like that, its just getting up in the project. Do you think that if I went with a clone for $20 with a 95 jet then later added that setup Id be ok? And thanks for supporting me on changing the crank, the votes are way in favor.
  Hobbit simple carb + setup for DR headTopic by: Ronald King Ronald King 07/01/19 07:16PM
  Re: Hobbit simple carb + setup for DR headRe: Ryan . Ryan . 07/01/19 07:22PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/01/19 07:25PM
  Re: Hobbit simple carb + setup for DR headRe: Aaron Blair Aaron Blair 07/01/19 07:25PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/01/19 07:35PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/01/19 07:29PM
  Re: Hobbit simple carb + setup for DR headRe: Aaron Blair Aaron Blair 07/01/19 08:56PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/01/19 09:08PM
  Re: Hobbit simple carb + setup for DR headRe: Jason Thompson Jason Thompson 07/02/19 12:20AM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 01:02AM
  Re: Hobbit simple carb + setup for DR headRe: Jackerz ! Jackerz ! 07/02/19 08:55AM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 09:38AM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/02/19 04:30PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/02/19 04:35PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 04:47PM
  Re: Hobbit simple carb + setup for DR headRe: Jonathan Feldman Jonathan Feldman 07/02/19 01:26PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 01:29PM
  Re: Hobbit simple carb + setup for DR headRe: Born to be WillD Born to be WillD 07/02/19 02:11PM
  Re: Hobbit simple carb + setup for DR headRe: Graham Motzing Graham Motzing 07/02/19 02:18PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 02:47PM
  Re: Hobbit simple carb + setup for DR headRe: Ryan . Ryan . 07/02/19 10:37PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/03/19 12:00AM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/03/19 10:46PM
