Re: Hobbit simple carb + setup for DR head
Marc Friedman /
The guy posted it as taking a sticker and putting s new Dr jug on it. I didn't see a mention of an aftermarket variator. Etc. Just to point out that I actually rebuilt my red Hobbit case with....a pa 50 1crank in primo shape because I was using at most a notched stock variator on it. Which is why I ended up with a pull starter rather than the one way bearing because I wasn't sure if I could figure out the correct bushings for a pa 1 one way. So far nothing bad has happened in five years. Yes it's not ridden every day. If this guy is working on a mild ride say 40 tops and he wants to get there fast with a mere 1 k on the pa 50 2 crank ...I say do it. Basically all he needs is a better head for heat shedding, especially if he is sticking with the decomp. That's my two cents.
  Hobbit simple carb + setup for DR headTopic by: Ronald King Ronald King 07/01/19 07:16PM
  Re: Hobbit simple carb + setup for DR headRe: Ryan . Ryan . 07/01/19 07:22PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/01/19 07:25PM
  Re: Hobbit simple carb + setup for DR headRe: Aaron Blair Aaron Blair 07/01/19 07:25PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/01/19 07:35PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/01/19 07:29PM
  Re: Hobbit simple carb + setup for DR headRe: Aaron Blair Aaron Blair 07/01/19 08:56PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/01/19 09:08PM
  Re: Hobbit simple carb + setup for DR headRe: Jason Thompson Jason Thompson 07/02/19 12:20AM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 01:02AM
  Re: Hobbit simple carb + setup for DR headRe: Jackerz ! Jackerz ! 07/02/19 08:55AM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 09:38AM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/02/19 04:30PM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/02/19 04:35PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 04:47PM
  Re: Hobbit simple carb + setup for DR headRe: Jonathan Feldman Jonathan Feldman 07/02/19 01:26PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 01:29PM
  Re: Hobbit simple carb + setup for DR headRe: Born to be WillD Born to be WillD 07/02/19 02:11PM
  Re: Hobbit simple carb + setup for DR headRe: Graham Motzing Graham Motzing 07/02/19 02:18PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/02/19 02:47PM
  Re: Hobbit simple carb + setup for DR headRe: Ryan . Ryan . 07/02/19 10:37PM
  Re: Hobbit simple carb + setup for DR headRe: Marc Friedman Marc Friedman 07/03/19 12:00AM
  Re: Hobbit simple carb + setup for DR headRe: Ronald King Ronald King 07/03/19 10:46PM
