I was on my way home a few days ago, and started hearing a clanking noise from what I thought was my front sprocket. If i went under 5mph the noise disappeared. I limped it as far as I could until the back wheel locked up. If you push the moped backwards a few feet you can push it forward for about 10-15 feet before it locks up again. Has anyone had a similar issue and found a solution? Thank you
