Re: 1977 Vespa Ciao Piaggio Won’t start
Les B. /
If it's not kitted, did you just put on that circuit pipe? I'm fairly new here, but if you did it probably is ran hot ,and it sounds like it seized as Stephen suggests. Mine seized last year I pulled the head. Sprayed lots of penetrating oil for a couple days and it loosened up. Luckily no damage. Try it. Hopefully you get more advice from seasoned members. Good luck kid!
