Re: Clutch sqealing noise- what is causing and how to fix
Largemouth Bass /
> Stephen Keller Wrote:
> Motorcycle shops are not always in tune with mopeds, is your exhaust
> clear? A blue spark should be good, I did not mean to insult your
> knowledge base, sorry if you took it like that. A weak spark can look
> good outside the cyl. You do have good fuel flow? Again just trying to
> help, will shut up now. :)
No no no I did not feel insulted.... I appreciate the help! I’ve tried premix down the sp hole and even starter fluid when I got frustrated. No need to “shut up” as you say I’m glad for any and all input
Edit: I did not even consider the exhaust would be plugged after only 300 miles, when it did run it seemed to run ok so I’m stuck on what it could be (edited)
  Clutch sqealing noise- what is causing and how to fixTopic by: Largemouth Bass Largemouth Bass 06/28/19 02:50PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/28/19 02:56PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 11:48AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 11:56AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 12:01PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 06:13PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 10:16PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 10:58PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 07/01/19 10:18AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/14/19 10:15PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 11:08PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/15/19 01:06AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/15/19 01:41PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Rebel Moby Rebel Moby 07/01/19 10:31AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 03:05PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: B the Moped B the Moped 08/19/19 12:04AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 08/14/19 06:25PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 11:10PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 08/15/19 06:29AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/15/19 01:21PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/15/19 01:55PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/16/19 05:03PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/16/19 07:11PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 12:44AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/17/19 01:07AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 08:03AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: P D P D 08/17/19 08:54AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 11:37AM
