Re: Clutch sqealing noise- what is causing and how to fix
Largemouth Bass /
> Stephen Keller Wrote:
> Check plug gap, spray some pre-mix into the cyl and see what happens,
> your ignition may not be bad at all? If points check timing? You may
> have a carb issue
Thanks for the tips but I’ve tried all of that stuff, I’m not new to small engines. I tried a new plug as well. I took the moped to a trusted shop and they said exactly what I thought, weak ignition. They said either the coil or stator was bad but since diblasi doesn’t have any resistance specs, I couldn’t test either and see which part is bad.
  Clutch sqealing noise- what is causing and how to fixTopic by: Largemouth Bass Largemouth Bass 06/28/19 02:50PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/28/19 02:56PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 11:48AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 11:56AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 12:01PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 06:13PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 06/29/19 10:16PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 06/29/19 10:58PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 07/01/19 10:18AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/14/19 10:15PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 11:08PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/15/19 01:06AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/15/19 01:41PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Rebel Moby Rebel Moby 07/01/19 10:31AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 03:05PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: B the Moped B the Moped 08/19/19 12:04AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Chris Carleton Chris Carleton 08/14/19 06:25PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/14/19 11:10PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 08/15/19 06:29AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/15/19 01:21PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/15/19 01:55PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/16/19 05:03PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/16/19 07:11PM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 12:44AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Stephen Keller Stephen Keller 08/17/19 01:07AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 08:03AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: P D P D 08/17/19 08:54AM
  Re: Clutch sqealing noise- what is causing and how to fixRe: Largemouth Bass Largemouth Bass 08/17/19 11:37AM
