What,what!?
This just came up in OFF TOPIC ! What’s up?
Re: What,what!?
Not on a mobile phone? Https is working on my sillyphone. Will check puter to see if I can reproduce this.
Re: What,what!?
yeah no problems here. perhaps your session expired. refresh or new tab ought to fix it.
Re: What,what!?
happens to me too sometimes,
my programming skillz ended around the time Tie Fighter came out but my guess is its an expired link that your browser snaps back to from your cache gigadot com server base mainframe.
Re: What,what!?
Chrome shows those very scary messages when someone is wrong the the domain name security certificate. In this case there is no threat, it's showing because the domain name "alpha.mopedarmy.com" is an outdated domain that is no longer in use and doesn't have the proper security certificate.
Can you point me towards where a link used this domain name? I'll try to track down this issue so it doesn't happen again but I'd like to understand how you ended up there in the first place as that's not an active domain name. (edited)
Re: What,what!?
Well there's your problem, that alpha shouldn't be there
Edit: my post apparently took 30 minutes to go through on my phone, I posted this before Simon chimed in (edited)
Re: What,what!?
I have now fixed this problem. There shouldn't be too many old alpha links out there, but now if you encounter one it just removes that portion and redirects you to the proper url.
Re: What,what!?
I didn't use a link Simon. I click MA on my favorites. Browsed, went to OT, that's what came up. Got spooked logged off. Went to iPhone no problem.( head scratch )
Re: What,what!?
Hmm, well, I'm not sure what caused it but it won't happen again after the changes I made.
