> Nick Haber Wrote:
> > Largemouth Bass Wrote:
> > > Nick Haber Wrote:
> > > Just look at what wires go to the headlight. Note their color, look
> > for
> > > any place where those color wires connect to other wires, make sure
> > > they're tight. It's gotta be a loose connection somewhere.
> > This problem just got even weirder. The normal headlight started
> working
> > but the "brights" don't. Sometimes it flickers a little when I'm going
> > over bumps and stuff and sometimes it even comes on. I've checked all
> > the connections I can think of but I'll look again.
> Assuming the high beam part of the bulb isn't burnt out, I'm willing to
> bet that this is an issue with your electrical controls. I have a CB550
> that has some loose connection or something in the hi/lo beam control,
> so my headlight will cut out if you touch the switch at all and it's a
> pain to get it to come back on. Take apart your controls, clean
> contacts, make sure no wires are uninsulated and rubbing together.
Are you talking about the switches on the handlebars? I will take a look at them after work tonight
