Re: Temperature dilemma hobbit PA50II
Marc Friedman /
So u built up the case with a Dr kit right ? So before the cylinder was slipped over the piston to build it all up , it's been said by many that one should carefully slip the rings off the piston or better yet if packaged separately, slip the ring into the bore of the cylinder. Now for a 45mm bore ( Dr I think ) the space between the two little ends of the ring ( there are several variations on the end and how they relate to their respective centering pin that has been carefully we hope placed along the groove that the ring lives at ( don't put wrong ring in wrong ringway ) the gap between the two ends should be 0.18mm NOT INCHES. IF U NEED THAT conversion let me know and I will look it up. Gentle filing if less is necessary for the simple reason that metal expands when hot. If the ends expand and kiss each other the ring will now gap out of it's little home. And the ring will accumulate even more heat until it decides to be come a welding stick and attach itself to the cylinder ....soft seize?? Hard seize....??? That's all I know. Sort of.
  Temperature dilemma hobbit PA50IITopic by: Jason White Jason White 06/24/19 01:39AM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/24/19 12:14PM
  Re: Temperature dilemma hobbit PA50IIRe: Dirty30 Dillon Dirty30 Dillon 06/24/19 12:17PM
  Re: Temperature dilemma hobbit PA50IIRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 06/24/19 12:59PM
  Re: Temperature dilemma hobbit PA50IIRe: William Johnson William Johnson 06/24/19 02:00PM
  Re: Temperature dilemma hobbit PA50IIRe: cheetahchrome . cheetahchrome . 06/24/19 03:01PM
  Re: Temperature dilemma hobbit PA50IIRe: Jason White Jason White 06/25/19 04:33PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/25/19 04:45PM
  Re: Temperature dilemma hobbit PA50IIRe: Jason White Jason White 06/25/19 07:12PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/25/19 07:24PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/25/19 06:45PM
  Re: Temperature dilemma hobbit PA50IIRe: Dirty30 Dillon Dirty30 Dillon 06/26/19 03:54PM
  Re: Temperature dilemma hobbit PA50IIRe: P D P D 06/26/19 03:57PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/26/19 04:14PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 06/25/19 06:51PM
  Re: Temperature dilemma hobbit PA50IIRe: Jason White Jason White 08/25/19 03:04PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 08/26/19 01:54PM
  Re: Temperature dilemma hobbit PA50IIRe: live ɘvil live ɘvil 08/25/19 08:30PM
  Re: Temperature dilemma hobbit PA50IIRe: Chris Szuba Chris Szuba 08/26/19 08:02AM
  Re: Temperature dilemma hobbit PA50IIRe: Jason White Jason White 08/26/19 01:48PM
  Re: Temperature dilemma hobbit PA50IIRe: Jason White Jason White 08/26/19 04:11PM
  Re: Temperature dilemma hobbit PA50IIRe: Marc Friedman Marc Friedman 08/26/19 04:39PM
