Try this first: As soon as the engine dies turn the fuel tap OFF. Then position a small container under the bike directly beneath the carburetor float bowl drain line. Now unscrew the float bowl drain screw and let the bowl's contents flow into the container so you can see how much fuel is remaining in the bowl. Please report your results.
